Bro8898
- Birmingham, AL
- Master Plumber
I’ve posted here before. You all have been wonderful and have given me so much to study and understand. I’ve made some progress based on your teachings and still have a ways to go. I’m grateful for the information I have received here.
How exactly is the neutral conductor “referenced” to earth? This question is from information I received in a previous question I posted.
I can understand that neutral is grounded (via ground rod) at the meter of every house, and often times grounded to the plumbing pipes. I also understand that the utility transformer is grounded, in many locations throughout the system.
How is earth zero volts? Or is it zero volts? Is it because of the grounding points I mentioned above? I can see how the neutral tap at the transformer is zero (or is it?) and I can see how a 120v circuit will flow in a path from hot (120) to neutral (0).
But I’m having trouble understanding where the earth itself comes into play. I also understand it’s for lightning protection purposes.
My struggle is in the case of an open neutral. I’m assuming that since the path has been lost, now the unbalanced neutral current is trying to find a way back to the ground rod at the transformer. It could flow through the house ground rod and through the earth and ultimately to the ground rod at the transformer but this is a poor path due to high resistance so it flows on the other 120v conductor and creates dangerous voltage differences that could cause lights to flicker and damage to appliances. I’m also aware that the plumbing piping system could “mask” the case of an open neutral by allowing the current to flow into the city main and through someone else’s neutral and back to the transformer (thank you all again for teaching me that years ago).
So if neutral is lost AND the plumbing system is not connected to everyone else’s (let’s say a water meter breaks the connection) and you have a situation where voltage ups and down are causing damage to appliances, if I were touching the pipes (that were grounded) or I went outside and grabbed the ground wire - wouldn’t current flow through me? It seems like I would make a good parallel path (in addition to the ground rod and piping system) from a grounded connection through my body through the earth and back to the ground at the transformer.
Are all the neutral connections to the earth causing the earth to be at zero volts? Are you basically making the earth zero when otherwise it would be nothing (floating basically)? I know that neutral is called the grounded conductor but in the case of an open neutral is it now ungrounded and trying to find a way back to the transformer through the ground which we have intentionally made zero volts?
You all have taught me that I have to be touching two things with a voltage difference between them in order for current to flow through my body.
I think I’m trying to understand the theory behind the idea of grounding the neutral (aside from lightning protection) and how the grounded conductor is referenced to earth. Or what that even means exactly.
Sorry for the long post and thank you in advance any input. Maybe there’s a book or some information out there on the internet that you all can direct me to. I’ve read these forums for hours and I would like to understand the theory behind this because I think it will help me to be more effective at what I do. This seems to be one of the most basic ideas and is key to understanding before moving on or even being able to have a relatable conversation with someone on the topic.
Thank you
Thank you
