Seven-Delta-FortyOne
Goin’ Down In Flames........
- Humboldt
- EC and GC
I’ve heard that one of the reasons the high leg is generally not used for line-neutral loads, like say running a 208v motor, is because the voltage is very often unstable.
I was on a service call the other day and I was checking voltages in a panel, and I noticed that the readings were normal, except when I would check B phase to ground, and then it would be all over the place for a few seconds and then settle down.
2 questions:
Is unstable high leg voltage the result of open delta transformer configurations, and would it be normal if 3 transformers were used?
And, what is it that causes the unstable voltage?
2 questions:
