Replacing receptacles
Jimmy7
Boston, MA
I have been asked to replace worn receptacles for an elderly couple in their single family residence. Some of the existing receptacles are above electric baseboard heat. I know that you shouldn’t mount receptacles above electric heat, but what about replacing worn existing receptacles? Isn’t at least better to replace worn receptacles at the very least?
Does Boston enforce 406.4(D) for replacements?
Doesn't answer his question does it? But if they do the old folks would be better off moving into an old age home. At least they might have a few dollars left.
To answer the OPs question, I would probably recommend that the blank off any that are above the heat or relocate them if possible.
-Hal
There is no code prohibition on receptacles above electric baseboard heaters. There is just an informational note mentioning that some heater instructions may say not to mount the heater below a receptacle.
'Sarcasm' needs to be assumed I'm his reply.
No sarcasm with new cover plates most likely to ignite the building.
New junk can melt, combust, or if metallic, create hot spots that ignite wallpaper.
Better not to touch existing devices.
New junk can melt, or if metallic, create hot spots that ignite wallpaper.
ignite: to (cause to) start burning or explode
Proof? Numbers?
Are they worse than the cord that may have draped across the heater for the last 30 years? Worse than the table leg or chair that technically is too close by .25 inch?
