pipe_bender
- Boston
- Electrician
Yeah EC's typically run a 6/2 NM which comes with a #10 ground.Connecting the undersized ground to the neutral terminal is IMHO a flat out violation on several fronts.
IMHO far better to leave the neutral terminal not connected.
Best (as you say) is to use the proper 6-50 configuration.
My 'quick fix' now is shorten the flex, lower the box, bond the box with a ground screw install a 6-50.
