They probably mean, "We will not support this unit operating on 380 volts." But it very well might work. If you were my customer, I would find a transformer to use. But if this were my machine, I would hook it up and see what happens.![]()
This was the feedback of miller tech assistant
The original poster says that a transformer is not an option.They probably mean, "We will not support this unit operating on 380 volts." But it very well might work. If you were my customer, I would find a transformer to use. But if this were my machine, I would hook it up and see what happens.
No. This could simply be one manual for two different models.Clearly the portion of the manual that showed the CE filter for the Euro zone approved model, shows that it can be made compliant for CE use.
He may not find a transformer that is exactly the ratio of 380:460, but he just has to get in the range. He may even have to use multiple autotransformers to get close. But it CAN be doneThe original poster says that a transformer is not an option.
Have a look at the data:He may not find a transformer that is exactly the ratio of 380:460, but he just has to get in the range. He may even have to use multiple autotransformers to get close. But it CAN be done
Excellent bandwidth for audio use.Have a look at the data:
5kH - 30kHz.
What do you make of that ??
It’s an induction heat treating machine. That’s the range of excitation frequency used by the induction coils. I’m no heat treating expert, but I suspect different frequencies are used depending on the target alloy, geometry and desired treatment.Have a look at the data:
5kH - 30kHz.
That's the frequency range of the induction heater.Have a look at the data:
5kH - 30kHz.
Exactly, So not so simple than your initial thoughts.That's the frequency range of the induction heater.
That has nothing to do with the input. What are you talking about?Exactly, So not so simple than your initial thoughts.
That's the output, not the input...Have a look at the data:
5kH - 30kHz.
Yes I know that. But it is a complex system and is not that simple as Emad has explained.That's the output, not the input...
No it is not.Yes I know that. But it is a complex system and is not that simple as Emad has explained.
Um............................No it is not.
That equipment comes from the manufacturer in one of two input voltage, both rated for 50Hz. The item the OP has does not match the source voltage he has. The only way to make voltages compatible is with a transformer on the input, or the OP equipment needs to sold and the correct item purchased.
This device is essentially a switch mode power supply. As long as you can get it to come on, the electronics inside will do whatever it takes to make the output. It is as simple as getting the input within a range that it will tolerate. If I couldn't get a new machine and I couldn't get a transformer that took me to the specs directly, I'd get whatever number of autotransformers as necessary to get close.Yes I know that. But it is a complex system and is not that simple as Emad has explained.
Which is why he needs a transformer to raise his supply voltage or he needs to by a different model. What is complicated about these two options?Um............................
"Hi Emad
This unit will not operate with 380VAC"
Seems pretty clear to me.
And that was the was the initial problem:Which is why he needs a transformer to raise his supply voltage or he needs to by a different model. What is complicated about these two options?
