brantmacga
Señor Member
- Georgia
- Former Child
I have no experience with solar whatsoever. I am still in the process of rebuilding my house from Hurricane Helene, and now that there are no trees around my house, I have the potential for a solar install.
My question is, as I'm getting ready to build the new service on my house, what should I do now to make future solar service equipment install easier? The exterior service will be a 200A meter and 200A disconnect, nippled through a 10" brick wall to the interior side of the garage. Inside the garage I'm going to have a trough w/ a transfer switch mounted above and a couple of pipes going into the attic (one routed to load center, one routed to generator). Is it as simple as adding a couple extra conduits to this trough for future solar equipment? Render attached of what interior side of the service will look like (in case my wife sees this post, yes all of that will be paint matched to the brick). That wall steps back in about 10" so this stuff won't be protruding into the path a car pulling in.
Georgia Power limits residential installs to 10kw.
Thanks.
Thanks.
