That was a epic boondoggle, took a lot perfectly good vehicles off the used car market.They could have another Cash For Clunkers. That would be cool
I mean if that was a good idea, why not have a "National Set Your Home on Fire Day", that would put us all on the Yellow Brick RoadThat was a epic boondoggle, took a lot perfectly good vehicles off the used car market.
They likely still didn't have much for incidents to base anything on. But this was about the time of the beginning of many things to come that didn't necessarily have much for justification either or were based on a rather unique single incident that had other contributing problemsIt took a very long time to make the code change to require the four wire circuit, because they could not cite actual incidents where there were injuries from the 3 wire circuit.
I've run into some very basic ranges that had the typical 120/240 supply terminal block with removeable bond link in the neutral, yet had no load neutral conductor landed on it. These had no oven light no timers. Just four basic infinite control switches for surface elememts and a basic oven thermostat.Bosch is the only range I know of that doesn't use Neutral to power their controls, fans, or even some convection elements.
