Electromatic
- Virginia
- Master Electrician
As a home project, I'm trying to convert the ringer of an old rotary phone for use as a doorbell. I thought it would be relatively simple, but I'm having no luck.
The phone is ca1970 Western Electric.
I know that the ring state for old POTS is typically around 90VAC, 20Hz. I've tried briefly applying 24VAC (from a transformer I have) and even straight 120VAC to what I believe to be the appropriate coil wires but get nothing. Is this to be expected? I thought I'd get some kind of reaction despite the out-of-spec V and Hz.
The coil assembly is (from research) apparently two coils for L1 and L2. Each one reads what I think is correct at ~1kΩ and ~2.6kΩ. There is also a capacitor within the phone's assembly that seems to be out of spec, reading ~1.2uF vs 0.5uF. My understanding is that this is more for actual phone line usage than the electromechanical operation of the ringer.
Am I completely missing something other than getting closer to 90V, 20Hz? I don't care about actually getting a "ring-ring" pattern--just for the bells to ring when someone presses the door bell button. (I know they sell ring generators, but I'm trying to keep it simple and cheap.)
TIA
TIA
