solarken
NABCEP PVIP
- Hudson, OH, USA
- Solar Design and Installation Professional
Because it's made for flex. Use a male threaded PVC adapter glued on>threaded coupling>EMT connector.Any reason to not use a set screw adapter typically used for flex,
Why not a female PVC adapter and a connector?Because it's made for flex. Use a male threaded PVC adapter glued on>threaded coupling>EMT connector.
-Hal
Do you mean the threads have not been evaluated for mechanical connectivity as opposed to electrical/ground continuity or is watertightness the issue?Note both of these ideas are not acceptable to some AHJs as the male threads of the connector have not been evaluated for use with female threads.
358.6: "EMT, factory elbows, and associated fittings shall be listed."But if listed materials are not required
That looks like its for ENT not PVC.View attachment 2582510This is listed for the purpose
The EMT would be bonded by a proper EMT fitting at the other end if terminated at a bonded enclosure and would only need a bonding bushing if the general rules for needing additional bonding methods call for it. The PVC would never need a bonding bushing.Would require a grounding bushing when terminated, depending. Use the flow chart for grounding bushings.
The simply have not been evaluated for any use with a fitting having female threads. The have only been evaluated for use with locknuts.Do you mean the threads have not been evaluated for mechanical connectivity as opposed to electrical/ground continuity or is watertightness the issue?
The page specifically said Schedule 40 or Schedule 80 PVC.That looks like its for ENT not PVC.
I didn't know a strictly mechanical connection need to be evaluated.The simply have not been evaluated for any use with a fitting having female threads. The have only been evaluated for use with locknuts.
