- Wisconsin
- PE (Retired) - Power Systems
Then make appliances that can be put into homes built before 2017.It's 2026,
Things just need to work.
Jap>
Jap>
I have no problem with GFCIs, just the expansion into places where they aren't needed and equipment that isn't compatible making for nuisance tripping. Like the old saying goes "if it aint broke don't fix it". Yes, they have been reliable for 50 years, so make equipment work with them not the other way around.They did a good job with GFCIs, their parameters lasted some 50 years, before they needed tweaking.
50 years ago we did not have the plethora of electronic motor controllers and power supplies, with their harmonics, that we have now. I can understand that some of our protection parameters may need to be tweaked. Kind of like we did with conductor ratings as insulation got better.Yes, they have been reliable for 50 years, so make equipment work with them not the other way around.
The appliances are fine. The problem is expanding GFCI protection where it's not needed and the forced adoption of AFCI that doesn't work.If the appliances are the issue, then why not make appliances that work with the electrical system that are required to be installed?
Jap>
Kinda sort of. I can think of one place where GFCI protection is needed and that is with pool pumps. If a pool pump won't play nice with existing GFCIs it should be up to the manufacturer to redesign the pump so it does, not expect the GFCIs to be redesigned. It's a lot easier to put power line filters in the back of a pump motor than it is in a little plastic GFCI housing.The appliances are fine. The problem is expanding GFCI protection where it's not needed
50 years ago we didn't think GFCI'S were reliableYes, they have been reliable for 50 years, so make equipment work with them not the other way around.
But they were, well maybe not some brands of receptacles, but overall we learned to live with them.50 years ago we didn't think GFCI'S were reliable
If you think about the state of technology back then it makes you wonder how something like that could be made in a small package. 50 years ago we had the brick phone. As far as GFCIs are concerned, the design could only be rudimentary with what components were available. So, I could see the skepticism which might have even been founded.50 years ago we didn't think GFCI'S were reliable
I've moved into full time commercial work since 2018, before that the shop I worked for did large custom homes, commercial and service work in both camps. Early on in the adoption of AFCIs I gathered a reputation as the guy who could excise the demons out of nuisance tripping AFCIs. I would go on a service call and find a neutral to ground fault or a crossed neutral on the circuit every time. I was among the crowd who said anybody who had problems with AFCIs needed to get their act together and stop blaming the breaker when it was lousy wiring practices that were the problem.One thing I have noticed about this forum is you all really hate AFCI's.
The other thing I notice is the long time posters whom are clearly long time practicing master electricians, who do residential, like @hbiss or @LarryFine to name a few rarely if ever seem to be the ones with a AFCI problem on their own electrical work.
Thank you. We hear these things are changing yet many don't really know what will change. This helps make sense of it. Sounds like it might be somewhat worthwhile change when you compare to how problems/solutions involving AFCI technology have gone.It is not a high frequency load, but a load that creates high frequency leakage current. It looks at the frequency of the leakage current and changes the trip point based on the frequency. The must trip for 60 hertz remains 6mA, at 2500 hertz, it is 12.9mA and at 10,000 hertz, it is 35.82.
I'm with you on expansion into places they aren't needed, been a lot of that in recent years. This HF technology if successful still can be pretty useful on some the 120 volt receptacles that many of us mostly agree GFCI is a good thing for yet there is high speed switching power supplies on things being plugged in nowadays that don't play well with old school GFCI devices. Might be able to argue if the refrigerator receptacle in the kitchen needs to have GFCI protection or not, but I have seen power tools with electronic speed or soft starting controls that don't play well with GFCI used for temp construction receptacles - which is an area I have strong feelings about GFCI protection being necessary for those particular receptacles. Too many people in other trades that have bad tool and extension cords, missing EGC pins, etc. and GFCI is a good thing because of this reason alone.I have no problem with GFCIs, just the expansion into places where they aren't needed and equipment that isn't compatible making for nuisance tripping. Like the old saying goes "if it aint broke don't fix it". Yes, they have been reliable for 50 years, so make equipment work with them not the other way around.
-Hal
My understanding the CPSC wanted them to develop something to protect against arcing faults to supposedly lessen house fires started by electrical issues that don't trip conventional overcurrent protection devices. What they came up with had issues, but the manufacturers weren't intending to lose out on what they put into R&D at that point and put some money into marketing it as well, but not so much to consumers, or electrical professionals in general but rather into convincing code making panels that these devices would save lives and property - get them into the code and you will have sales, otherwise they won't sell especially after all the undesirable tripping that did happen with them, and they most likely knew it wasn't fully ready but weren't going to take the losses on R & D either, let the consumer be the testing lab to discover what issues may come up with them. That is a little how the combination type came about. We were told before that these devices would trip for series and parallel arcing events, then they ended up creating a new device that will trip on both series and parallel arcing and acted like they never claimed the old ones would do that? And if they fix a problem they update the product, possibly even offer to replace an old one, but certainly not reimburse the installer for his part in dealing with the issues even though he may have spent hours trying to figure out if he did wrong or if product wasn't performing as intended. After all they tended to keep the how it works details somewhat top secret so nobody knows what is going on with it when it doesn't do what is expected to do.AFCIs are a fraud. The manufacturers knew it and rammed them into the code anyway. That's why I hate them.
I was explaining this topic to a friend who happens to work in software and she said that just like you might open a breaker to see how it works, people want to open up her code and inspect it. Some standards require software code to be delivered with the device or even published as 'open source' for security inspection. She said its quite common, back to the Unix days even Unix itself was that way.After all they tended to keep the how it works details somewhat top secret so nobody knows what is going on with it when it doesn't do what is expected to do.
The issue isn't really the breaker code itself. The problem is undefined required parameters. Evidently each AFCI can have its own signature in order to get a UL label.I was explaining this topic to a friend who happens to work in software and she said that just like you might open a breaker to see how it works, people want to open up her code and inspect it. Some standards require software code to be delivered with the device or even published as 'open source' for security inspection. She said its quite common, back to the Unix days even Unix itself was that way.
She suggested the that NEC mandate that any 'code' that runs on something as critical as a over-current device should really be accessible for inspection, in they same ways you can open the breaker and inspect its parts.
They can still own their patent on it but they have let others inspect the code if it runs on a breaker. She has similar requirements at her work its a bit over my head but thought I'd share the comment.
The equipment is tested and listed to the product standard. With hard wired appliances the listing did not care about leakage current that trips GFCIs, because they correctly assumed that the EGC eliminates the safety hazard from leakage current from a hard wired appliance. Those standard have to be changed to work with the expanded protection requirements in the NEC. It takes at least as much time, and often more time, to change a product standard than it does to change the NEC. The product standards are ANSI consensus standards just like the NEC, but without an automatic update every 3 years like the NEC.Why is it that they don't delist all the stuff out there that nuisance trips GFCIs and make manufacturers take responsibility? That stuff should have been tested for this and shouldn't have been listed to begin with
