I don't think it is a detail when it is simply inaccurate.Your obsession with this terminological detail crossed the line from being informative to being annoying a long time ago.
Cheers, Wayne
GoldDigger has already pointed this out.
Cheers, Wayne
Terminology is conventional and may choose to emphasize different aspects. As there are no utilization loads I am aware of that depend on the phase difference between the two L-N legs of a 120/208V system, such a system only supplies single phase loads. So in this case, the terminology is based on what the system actually does in practice, not what it could do in theory. It is not up to you or me to decree that the terminology has to be based on the underlying physics.I don't think it is a detail when it is simply inaccurate.
I know exactly what it is. Just 208V and 120V are not in phase.Terminology is conventional and may choose to emphasize different aspects. As there are no utilization loads I am aware of that depend on the phase difference between the two L-N legs of a 120/208V system, such a system only supplies single phase loads. So in this case, the terminology is based on what the system actually does in practice, not what it could do in theory. It is not up to you or me to decree that the terminology has to be based on the underlying physics.
If it makes you happy, when you see "120/208V single phase" just insert the word loading as you read it to yourself, as in "120/208V single phase (loading)". Or perhaps "120/208V single phase (loading; 2 of 3 phases physics)." That information is understood by any knowledgeable reader.
Cheers, Wayne
Good, so then you can understand that the name may not depend on the physics, but rather on what type of loads the system is used for. The name can't be accurate for both the loading and the physics, and in this case the convention is to go with the loading. Please recognize the convention.I know exactly what it is.
Yes, a convention. But it is not single phase..Good, so then you can understand that the name may not depend on the physics, but rather on what type of loads the system is used for. The name can't be accurate for both the loading and the physics, and in this case the convention is to go with the loading. Please recognize the convention.
Cheers, Wayne
What is is? : - )Yes, a convention. But it is not single phase..
Yes,, one phase angle. How else could you describe it?What is is? : - )
I think we've covered that you might call a system "single phase" because it only supports single phase loads. Or you might call it "single phase" because it has only one phase angle present. It's not clear to me that the sentence "the system is single phase" necessarily means the latter rather than the former. I would say it is ambiguous.
Cheers, Wayne
As we've been discussing, by the type of loads the system supplies, and how many phase angles they require.Yes, one phase angle. How else could you describe it?
Thus many phases would not be single phase.................As we've been discussing, by the type of loads the system supplies, and how many phase angles they require.
Cheers, Wayne
