david
- Pennsylvania
If you ever where in the military being out of step is not walking faster than everyone else. It is leading with the right foot when everyone else is leading with the left foot. Cadence are called out left right left, not right left right.
You are correct that a receptacle is a device and a switch is a devise.
A receptacle is a contact device and a switch is a switch devise.
The NEC Knows that the definition for device does not include automatically a point in which utilization equipment receives current from a building wiring system.
And outlet is the last point in the circuit the point in which utilization equipment is supplied current from the building wiring system (branch Circuit)
Except the fact that the NEC went further and defined the receptacle device when connected to a building wiring outlet as a receptacle outlet.
Current does not leave the building wiring system to supply utilization equipment at the swath devise it continues to the final outlet that is the supply point to the utilization equipment.
Finally yes your example of a disconnect for a AC unit with a Knife switch certainly can be defined as an outlet.
Not always the last point but in this thread the last point in the circuit.
