kwired
Electron manager
- NE Nebraska
- EC
What is called two phase here, is a mostly obsolete system but some are still in use, and is mostly out in eastern US areas where you may find it. True two phase generator has two windings 90 degrees from one another, you can connect it to a "two phase motor" and not need any capacitors to create a phase shift like you do with "single phase motors".My own, although again, technically student level of understanding, is the USA uses a two phase system, the two phases actually 180 degrees out of phase of each other, and the uK and Europe use a three phase system, where the phases are 120 degrees different from each other, but wiring is still basically similar. When a business is wired with three phase here, it is five wires into the residence from the electrical supplier, three lines, a neutral and a ground, or it is simply three lines into a transformer, all three lines being live, and the ground and neutral starting at the transformer rather than the utility. Slightly different from the US as most all residences have their ground, neutral and live wire go to the nearest utility transformer.
A typical 120/240 three wire system is single phase from one end of source winding to other, and single phase from either end to the center tap. There is no way to direct connect it to an induction type motor without artificially creating phase shift in that motor to develop rotating magnetic field in that motor, which is done with capacitors or windings with different inductance, or many times combination of both.
