winnie
- Springfield, MA, USA
- Electric motor research
4 phase lasagnaWhats for dinner?
208 a phase A 10 amps phase B 5 amps neutral amps = ??????????????????????????????????????????????????????????????????????????????????????
Now that sounds awesome...4 phase lasagna
Is there a problem with asking for some clarifying information instead of questioning someones motives for posting or making judgments about someones skill level?Said 3 PHASE, yet no C phase load in that at all. Are we to just guess?
I was probably 3 down in the whiskey! Agree, sounds a bit aggressive.....Is there a problem with asking for some clarifying information instead of questioning someones motives for posting or making judgments about someones skill level?
As long as the whiskey was good…..I was probably 3 down in the whiskey! Agree, sounds a bit aggressive.....![]()
Turkey 101 FTW. I have many others that are better, but Turkey is well rounded.As long as the whiskey was good…..
The question is clear to me:208 a phase A 10 amps phase B 5 amps neutral amps = ?
A = 10a
B = 5a
C = 0a
N = ??a
You might want to revisit that.In = sqrt(Ia^2 + Ib^2 + Ic^2 - (Ia*Ib + Ib*Ic + Ic*Ia))
In = sqrt(10^2 + 5^2 + 0^2 - (10*5 + 5*0 + 0*10))
In = sqrt(100 + 25 - 50)
In = 13.2 A
You're right. I added when I should've subtracted. It should be sqrt(75), rather than sqrt(175), which would give 8.66 Amps.You might want to revisit that.
They started producing it this year with an 8 year age statement. Highly recommended if you can find it.Turkey 101 FTW. I have many others that are better, but Turkey is well rounded.![]()
Whisky doesn’t mix with arithmetic.You might want to revisit that.
My calculator must be better, 8.66 amps.0 load on C phase I get 8.7 amps on the neutral.
The mnemonic to find neutral current, assuming unity power factor for all phase currents:
"Someone spilled SOS, in the house. To remove it, and have None left, we'll SOP it up."
SOS = sum of squares, sounds like sauce
SOP = sum of products
N for None = Neutral current
Remove = subtract
The house = the square root sign
Only if the power factor is unity.Can somebody more mathy than I explain if the SOS/SOP formula above is also correct?
It was an AI question on FakeBook. Seen it earlier this week.Somewhere, the OP is smoking a cig......after tossing an apparent grenade in a foxhole, then waiting for the drama. Amazing.
Maybe it's too much time in engineering as opposed to EC, but loose ends are a no-go. UNITS! And you define everything, so there can be no question. A=10, B=5, C=0. Thank you..... For those that say, "it's not defined, so it's 0", that is what we call ASSUMING. We don't do that here! Even though common sense might point otherwise, it's about the paperwork.
At an early age, I learned units are important. People say I was driving 55 but got pulled over. More to that, driving in CanUHDuh with a USA car doing 55mph in a 55kph zone. Cross the T's.
