winnie
- Springfield, MA, USA
- Electric motor research
From 208Y/120 3P4W, or from 120/208 1P3W?
Cheers, Wayne
Starting with 120/208 3 wire (with the neutral).
-Jonathan
Cheers, Wayne
In a heating appliance, the actual surface temperature of the heating element is probably 1200deg F, so at 208V would be 800F, still a LOT more than the air temperature you cook with. So other than the time it takes to change the air temperature in the oven, it’s not that relevant. Ultimately, the only consistent effect is it’s recovery time after opening a door, or convection losses through the walls. Most people don’t notice.Indeed. Which, in my opinion, is not really just not really a little less heat. Sorry Mr Jreaf..........
I still disagree with you. Note the comment that LarryFine posted - 75%In a heating appliance, the actual surface temperature of the heating element is probably 1200deg F, so at 208V would be 800F, still a LOT more than the air temperature you cook with. So other than the time it takes to change the air temperature in the oven, it’s not that relevant. Ultimately, the only consistent effect is it’s recovery time after opening a door, or convection losses through the walls. Most people don’t notice.
Not a lot of depth to it. 240 V and 208V are just two different voltages. Or any voltage in between.I am shocked that we are on page two discussing deep theory when the bottom line is that a Buck Boost transformer is not an acceptable method of providing voltage adjustment to a varying load, of which, an RV certainly is.
Maybe I'm an old faart but can you explain what an RV system is?And to bring it back to the OP, repeating what has already been said: for a normal RV load 120/208 and 120/240 are perfectly interchangeable because the RV electrical system is designed to use either interchangeably.
-Jonathan
I am shocked that we’re still discussing voltage conversion when RVs clearly don’t need it.I am shocked that we are on page two discussing deep theory when the bottom line is that a Buck Boost transformer is not an acceptable method of providing voltage adjustment to a varying load, of which, an RV certainly is.
The typical RV has small version of the panel we have in our homes, sometimes called “split phase.” In a home, 240V loads are connected line to line, while 120V loads, line to neutral.Maybe I'm an old faart but can you explain what an RV system is?
For us (EU and UK) it is simpler for us. Domestic residences are just simpler - it is all 230Vac. Wouldn't that be easier than the US of America?The typical RV has small version of the panel we have in our homes, sometimes called “split phase.” In a home, 240V loads are connected line to line, while 120V loads, line to neutral.
The key difference is that RVs only have 120V loads. Some connections in RV parks will have a receptacle that ultimately connects both line connections in the RV panel to the same source line (phase). The RV doesn’t have 240V line to line, but the user never notices.
Yes, I do know what an RV is in USA - you do that my dear wife is from Georgia?RV = 'Recreational Vehicle' https://en.wikipedia.org/wiki/Recreational_vehicle
I think 'caravan' is a more common term in the UK.
Large versions of these have 50A 120/(240 or 208)V power inlets. At a campground you pay for a parking spot with services such as electricity, and plug your RV in.
When the revolution comes, I will make power companies deliver 240/208/120/120 hexaphase to everyone's home. Complexity builds character!For us (EU and UK) it is simpler for us. Domestic residences are just simpler - it is all 230Vac. Wouldn't that be easier than the US of America?
And you've not had to install 120V 60Hz receptacles in your home?!?Yes, I do know what an RV is in USA - you do that my dear wife is from Georgia?![]()
Well, you did ask what it was!Yes, I do know what an RV is in USA - you do that my dear wife is from Georgia?![]()
Well, you did ask what it was!![]()
Of course not !!When the revolution comes, I will make power companies deliver 240/208/120/120 hexaphase to everyone's home. Complexity builds character!
*grin*
The poster was saying the RV/recreational vehicle has a panel (breaker/power panel) in it similar to what is in a home."The typical RV has small version of the panel we have in our homes,"
"RV = 'Recreational Vehicle"
One of the posters here called it an RV or a Caravan which is similar for the UK version. We wouldn't have used the in a house. C'est la vie.The poster was saying the RV/recreational vehicle has a panel (breaker/power panel) in it similar to what is in a home.
In every post here, using the term "RV", they were referring to a recreational vehicle.
Follow up question on what exactly you mean by the above. I would take it to mean that the n coils on a transformer are connected together in a manner equivalent to a single coil with n+1 connection points along its length. Is that what you mean?as an autotransformer.
Thanks,
Wayne
