180105-1627 EST
mannyb:
Apparently all present machines are single phase 240 V.
Any that do not have high initial loads, and are not generally run at full load can probably run at 208 with no problem. This would include drill presses, sanders, small tool grinders, and hand tools.
Anything with a high inertia load, for example a radial arm saw with a large diameter saw blade might be a problem on start up.
An air compressor may have a high initial load. The air compressor motor probably should be replaced with a 3 phase motor, at least if it is in the 5 HP or higher rating.
If the 208 source is very stiff, little voltage drop under load, and you use low impedance wiring from source to the load, then the high initial loads may not be a problem.
At no steady-state condition do you want to run a load current higher than rating.
A future CNC machine should have input taps that allow 208 operation.
