- Windsor, CO NEC: 2017
- Service Manager
Re: 3-way switch loops
Factory paint is still paint.
An integral clamp that moves inside the box is still internal.
Over-specification creates loopholes, as demonstrated time and time again in the NEC. Here is one instance where over-specifying criteria for an action did not take place, and that's exploited?
In that case...Originally posted by peter d:
Yes, I do push the cable in and it bends the clamp down into the box, thereby taking up space. However, until the code changes the wording from "internal" to "internal and intergral" I don't think we need to count integral box clamps in calculations.
...until this states that factory applied nonconductive coatings shall be removed, I will not remove them because they are not specifically referenced.250.12 Clean Surfaces. Nonconductive coatings (such as paint, lacquer, and enamel) on equipment to be grounded shall be removed from threads and other contact surfaces to ensure good electrical continuity or be connected by means of fittings designed so as to make such removal unnecessary.
