Carultch
- Massachusetts
What is the ambient temperature![]()
-Jon
Usually the basic derate for ambient temperature, typically 0.96 as most US ambient temperatures are slightly above 30C, is not enough to reduce the 90C wire ampacity below the 75C terminal ampacity. And the 75C ampacity is what you start with, no adjustments or corrections for temperature, in most cases for terminations. The 90C ampacity is what you get to use for temperature correction and bundling adjustments, which is a different value limiting the wire amps.
