georgestolz said:
I am so not getting your point either.
You've made that quite obvious.
georgestolz said:
Your first post in the thread was a way off-base interpretation, so don't even give me that.
I'm not interpreting. I'm reading and quoting the written words.
georgestolz said:
You're making this leap from minimum requirements to somehow encompass a service 300A over the minimum, and twisting the words. It's your job to summarize the sentences in a way that makes your case, you can't just wave a magic wand and say the words mean something totally different.
No leaping or magic wands here. And I'm certainly not twisting the words.
georgestolz said:
We have a 400 amp service disconnect with a 375A calculated load, and 500 MCM CU service conductors, let's say for a house.
By calculated load, do you mean as specified in 230.42(A)(1) or (2), as appropriate, or do you mean the calculated service load of Article 220 Part III. The results are usually not the same, and we are talking about service entrance conductor ampacity here, you know.
georgestolz said:
Check for compliance:
230.42(B): Is the ampacity greater than for the service conductors not less than the service disconnecting means specified in 230.79? Check. For a house with a minimum service, #2 AL conductors are required.
The first part of your question makes no sense. And I certainly have no idea how #2 AL conductors enter this picture.
georgestolz said:
What section are you going to cite to fail this installation?
None. I'm not associated with any AHJ.
georgestolz said:
There's thinking outside the box, and there's wearing a box over your head.
Which are you doing?
Neither. Comparatively speaking, I'm observing the box.
_______________________________________________________________
Let's try approaching it in the form of a math question:
What condition is placed on X if
Y = 400 and the following conditions are satisfied?
Condition 1: X ≥ Y. Condition 2, A through D apply to Y.
Condition 2: Y is conditional upon its color as follows,
A) If Y is black, Y ≥ 15
B) If Y is red, Y ≥ 30
C) If Y is blue, Y ≥ 100
D) For all other colors of Y, Y ≥ 60
