Which contradicts this from post #3:Load should always be determined in KVA. Amps means nothing until you size the conductors and select the breaker size.
If you put all the load on a single phase of a three phase panel, add up the total KVA of that phase, multiply by 3, you will get the minimum size of your 3-phase transformer.
What matters is only the total KVA of the loads.
That's the point I was getting at.
