Hi All,
I'm trying to understand what AWG of SOOW cordage should be used for a 3 pole 4 wire 50A feed?
Scenario: A design is rated for 40A max continuous (3 pole 4 wire 208VAC), and therefore per NEC will have a 50A feed and a 50A (40A*1.25) internal breaker. Using NEC Table 400.5(A)(1) leads me to believe I should select 4AWG and not 6AWG. But the CS6365C 50A twist lock plug is only rated for #10-#6AWG and not the 4AWG I would expect. Beyond that it seems like I've seen instances of 6AWG cordage for 50A services. Do I need to stick with specifying 4AWG or can 6AWG be used and comply with NEC?
Thanks, Wayne
Thanks, Wayne
