mikeames
- Gaithersburg MD
- Teacher - Master Electrician - 2023 NEC
I use split bolts almost daily for Utility Side, and use (Used) them very frequently for other side of the meter. A good pair of pliers and the right size socket a split bolt is simple to install. 1 1/2” tape makes short work of the taping. I wrap mine with a layer of rubber tape first, then follow it up with vinyl.These days fewer people new to the profession know how to properly tape a split bolt for both electrical and mechanical protection. And it is, IMHO, the most labor intensive part of the job.
Agree... I don’t have a problem with big blues either.
Mine gets a half twist.Never pretwist 8 or 6 because it's stranded. Installing a Big Blue will twist 'em up more than enough.
"Back in the day", long before multi port Polaris and the like connectors were invented, it was common practice to put as many conductors as would fit (even mixed sizes) in a split bolt. Don't remember any failures.I use split bolts almost daily for Utility Side, and use (Used) them very frequently for other side of the meter. A good pair of pliers and the right size socket a split bolt is simple to install. 1 1/2” tape makes short work of the taping. I wrap mine with a layer of rubber tape first, then follow it up with vinyl.
FWIW, the only split bolts I have ever pulled off that were failing were on the service drop at the weather head, and they were the aluminum split bolts
One of the most endearing things about you guys is your ability to make a mountain out of a mole hill.
It's all about the story.One of the most endearing things about you guys is your ability to make a mountain out of a mole hill.
For the love of everything: UF from panel to island sleeved in pvc while in concrete.
About only ones I seen fail were used with aluminum conductors, even when designed for aluminum.I use split bolts almost daily for Utility Side, and use (Used) them very frequently for other side of the meter. A good pair of pliers and the right size socket a split bolt is simple to install. 1 1/2” tape makes short work of the taping. I wrap mine with a layer of rubber tape first, then follow it up with vinyl.
Kind of what I was thinking...Got it done that's good. Looking at the photo without doing a calculation I'm guessing that the conduit is too small. Now if you call it a sleeve?
trouble-makerGot it done that's good. Looking at the photo without doing a calculation I'm guessing that the conduit is too small. Now if you call it a sleeve?
1-1/4 PvC
How do you do a pipe full calculation for those two conductors?
I remember doing it for NMB wire 12 -2 But not this particular wire
6-3 UF
12-2 UF
1-1/4 schedule 80 PVC
6-3 UF
12-2 UF
