jwelectric
- North Carolina
Re: 6 disconnect rule violation?
Your reference to 210.7 of a multiple circuit only stated that if I take two different circuits to a device on a single yoke that this breaker must have a common trip. A handle tie would not be allowed.
210.7 does not give permission to use handle ties on multiple circuits in any way nor does in insinuate that it would be allowed.
210.4 tells us how a multiwire circuit can be installed and when a common trip breaker is required to be used on a multiwire circuit. Just as in 210.7 when a multiple circuit lands on a device that is on a single yoke it must have a common trip.
This is so that all power is turned off this single yoke when the breaker is turned off either manually or in trip position.
240.20(B)(1) addresses breakers used in a multiwire circuit. Here we are told that on a multiwire circuit that we can use a handle tie but we are not required to use a handle tie on multiwire circuits.
In your previous post December 23, 2005 06:36 PM you make this statement
Explain to me how you will break off the tabs of a receptacle and feed it with two different circuits, each with its own neutral each on the same phase and comply with 210.7. Didn?t it tell us that in this situation that there had to be a common trip?
Now lets look at 225.33 the article in discussion.
225.33 addresses the maximum number of disconnects that can be used at a remote building.
Subsection (A) covers the general requirements of the maximum number and limits it to six.
Subsection (B) addresses the use of single pole units as part of the required six disconnect maximum rule. It states that a ?multiwire circuit? that consist of two or three single pole breakers can be used as a single multipole disconnect as long as it is equipped with a handle tie.
Nowhere does this subsection address the use of single pole units and give permission to use a handle tie for multiple circuits. It is very clear that when using handle ties on single pole units that they must be part of a multiwire circuit.
Everything else that is mentioned about handle ties or single pole breakers in the code book can be forgotten simply because 225.33(B) addresses the use of single pole breakers as they pertain to the use as the six disconnect rule outlined in 225.33(A).
Today is Christmas Eve and a very busy cooking day for me. Hope you have a great day today and if I don?t get back a very Merry Christmas tomorrow.
This is a very good attempt to try to slide the use of handle ties in on the panel addressed in this thread but I don?t think that 240.20(B)(2) nor (3) would apply as (B)(2) is addressing DC circuits and (B)(3) is addressing 4-wire, 3-phase systems or 5-wire, 2-phase systems.Originally posted by hurk27
I showed you two places where the code allows handle ties for non- multiwire circuits
A circuit that only supplys line to line current is not by the definition in the NEC a multiwire branch circuit, It does not have a neutral.
240.20(B)(2) and (3)
Well I will admit that I am not the brightest bulb on the string but I am smart enough to figure out that this just will not fly either.Originally posted by hurk27
210.4(A) does not say multiple Branch Circuits are permitted to be considered as multiwire circuits does it? No it doesn't it say's that a multiwire branch circuit can be considered as a multiple branch circuit!
Why? well multiple branch circuits can have ungrounded conductors on the same phase because each will have it's own neutral run to it.(and would no longer fit the NEC's definition of a multiwire circuit)
Ever wonder why the neutral side of a duplex receptacle has the same break off tab that the hot side has? well now you know.
