mivey
Rick, it is pretty common terminology to say that the two ends of a center tap transformer are 180 degrees out of phase when the center tap is grounded. This is quite common when making full wave rectifiers without using a bridge rectifier.
Just to clarify what you are saying, are you disagreeing with the following statement that the center-tapped transformer has voltage phasors with a phase difference of 180 degrees?:
Or, is there something in his diagram/statements that is indicating something in addition to this common 180 degree phase difference concept?
I can't be 100% sure, but it appears that this is what rattus is trying to say.mivey said:From pg 90 of "Techniques of Circuit Analysis" 1972 Carter/Richardson where they were talking about forming polyphase sources by using voltage sources separated by phase differences:
"...two voltage phasors in opposition-that is, with a phase difference of 180 degrees; a single-phase transformer with a center-tapped secondary winding would be such a source."
