Agreed!
Agreed!
Agreed,
Whether you subtract a phasor or change its sign and add, it doesn?t matter because the processes are identical, and I see nothing in Kirchoff to favor one wording over the other.
There is no such thing as "negative magnitude" either.
Now, please explain your repeated references to my error since you agree that subtraction of phasors is OK. My results were correct as well.
Agreed!
Rick Christopherson said:The difference between the two drawings is that Smart$ used vector subtraction, and I used vector addition. It is simply personal preference. I prefer to always use vector addition. It doesn't matter when there are only two vectors, but when you get into a more complicated problem with multiple vectors, then addition is more straight forward.
Agreed,
