1. Can romex be run from residential garage sub-panel to garage exterior wall JB, and spliced to incoming THWN from 3/4" PVC underground ckt for above ground pool receptacle? The reason I ask is someone mentioned ground wire had to be insulated, but I thought there was an exception for residential? I understand the pool is 48" deep, which means it must comply with part 2 of 680 (for permanent installed pools).
2. Confirming; Equipotential bonding does not get connected to sub-panal or ground rod, just ring around pool, 4 points attached to pool, hit water skimmer for water bond, and circulation motor ?
