overloader
- suffern, ny, US
Gentlemen:
Electric service customer needs to have a ground rod added to residence with existing cold water pipe ground. Water pipe entry is back to back fittings, couplings, and gate valve on street side of meter. There is exactly one inch of pipe clear for the grounding clamp. That's where it is. Customer (me..retired electrical engineer) will be hiring an electrician to install grounding rods. If there were room on the cold water pipe for a second clamp I assume the electrician would be running a new ground wire from the second clamp on the pipe out to the ground rod...job done. Since there is no room for another pipe clamp I assume 1: The existing connection at the neutral block will be removed. 2: A ground wire from a new pipe clamp would be lengthened to bond to the ground rod, and when the ground wire reaches the rod it would make a right turn back to the neutral block. Does this make sense? It would be much easier to just put in the ground rod and run its ground wire to another spot on the neutral block. I have never seen this done on any forum, so I assume that a neutral block is NOT a bonding point, and a code violation if used as such. I would like to know how to hire an electrician who is mature enough to permit a customer to examine the installation. My concern is insurance collection after a possible lightning strike. In my neck of the woods the building inspectors are for all purposes political appointees and I consider them unreliable. That's why I want to do my own inspection. Is this the place to get advise on this matter?
