Newsletter Writer
- Toronto, Canada
- Aircraft Pilot
Hello Folks:
I'm not an electrician. I have been asked to write an article for our condominium corporation newsletter to advise homeowners that they might need to upgrade their home's electrical panel from 100 amps to 200 amps if they purchase an electric car and want to install any form of charger for the car other than something that plugs into a standard 110 volt 15 amp outlet.
It's not my intention to tell homeowners how such an upgrade is done. The purpose of the article is to advise homeowners to investigate, with an electrician of their choice, exactly how much work will need to be done and to determine with their electrician what this will cost before they purchase an electric car.
Our community consists of 70 townhouses in Metro Toronto that were built in 1980. The units have between 1 and 3 bedrooms and vary between 1,500 and 1,900 square feet, including the finished basements. When the units were built, none were equipped with air conditioners, and all were fitted with 100 amp service panels. Since then, every single owner has added an air conditioner.
When I look at my service panel, which is typical of all the other units in our community, I see the following:
Our Property Manager believes that if a homeowner wants to install a charger for an electric car (other than a 110 volt, 15 amp plug-in charger) the homeowner will need to have their electrician do the following:
Thank you very much for any advice and criticism you can provide, and thank you also if you can provide me with any web links you think I should include in the newsletter article to better inform homeowners about what they need to know.
- All the breaker spaces are occupied, there are no empty spaces left.
- There is a 20 amp double breaker for the air conditioner, and two 40 amp double breakers, one for the dryer and one for the stove.
- There are three 15 amp double breakers that service kitchen outlets.
- The remaining twelve 15 amp breakers service lighting, the fridge, the smoke detector, and other outlets.
- Upgrade the size of the electrical panel from 100 amps to the next largest commonly used size (presumably 200 amps).
- Install, at homeowner's expense, a new set of wires in the conduit leading from the electrical meter to the power panel.
- Possibly install a new base plate for the electrical meter (this depends on whether or not the meter base plates were upgraded in 2017).
