LarryFine
- Henrico County, VA
- Electrical Contractor
The small conductors would flatten under the screw heads as they expanded from heat, and be looser causing more heat. Cycling loads would make the effect snowball until the connection overheated.
A thorough terminal tightening would restore contact, improved with the increased contact area with the flattened wire, and buy you another 40 years of use.
