cschmid
- Northern cold country
LOL Now I feeling just alittle dumb..the POCO have that here as well..
The current does go back to its source, but it does so using all available paths and the grounding electrode provides a path back to the source. In the case of a common metal underground water piping system, a very good path that will often carry 25% or more of the service grounded conductor current.There should be no current on the grounding electrode/water line period I have been told repeatedly that current doesnt go to ground it goes back to the source.
In a perfect world no kind of. I do not look at it that simplisticly. Electricity is acted upon by all sources and current paths in my world.iwire said:Do you disagree with that?
LarryFine said:The majority of current will take the path with the lowest impedance, regardless of why.
coulter said:Larry -
Are you saying that a 1 ohm aluminum conductor path will pass just as much current as a 1 ohm copper conductor path -![]()
blasphemy! Everyone knows that copper is a better conductor than alumunum:roll:
That would be because remote paths have a higher impedance as a result of the inductive reactance.while portions of the current take all available paths, that a majority of the current will try to flow close/adjacent to the phase conductors, be that on the neutral conductor (assuming it is intact) and the GEC, ...
Nope - just off. Frivolous moment attack - I'll keep them to a minimumLarryFine said:...In the off chance you're being serious, ...
Whew!coulter said:Nope - just off. Frivolous moment attack - I'll keep them to a minimum
Brian, quit running yourself down. I daresay a majority of the members here are humbled by (if not, at the very least respectful of) your experience, and contribution of it here.brian john said:(or been told by someone more knowledgeable than me*) * And believe me those folks are everywhere.
