erickench
- Brooklyn, NY
....along with that any metal conduit that may be involved should be changed to PVC...
Actually if there is a metal conduit electrically continuous going back to the service then you should leave it as it is. You would'nt have to use a nonmetallic box. That conduit is the equipment ground. The fault current flows from the box through the conduit and then to the service neutral.
