- Wisconsin
- PE (Retired) - Power Systems
No more than field punching a conduit entry,in the back box, would.Wouldn't that void the UL listing?
Chances are you do make it look hack with a grinder, and so do most of us. But what are the chances you take it someplace where they can get a nicer machined edge that looks just as clean as the original edge?Oh, God, no. No reason for me to make it look like a hack job with my grinder. LOL
Worst case I'll have the framer put an extra stud between them and throw the centers off for the sheet rockers. I won't be able to understand a single cuss word they will scream anyway.![]()
But isn't that somebody else's problemI think the issue might be more getting the 1.5" strip of rock between them to stay screwed/nailed and not split.
I've long time wished they made the 3R ones so you could flip the inside over and have it bottom fed. I bet I bottom feed at least 75% of the ones I install and have no need to put the main on top.I wish the cover's were symmetrical where I could spin the insert over and put both door opening to the outside and keep both mains on the bottom like that.
I bet I can take my grinder, cut the center out of the cover plate, keep the insert where it is, and spin it, then weld it back on and re-paint it so the doors would both open out on both panels......but then I'd loose my UL listing. LMAO
So why not just go with a single 400 amp panel with 84 spaces then?Im with Curt. If it was my house I would install 2 studs between. I'd also install a nipple between the two. I'd also use real panelboards and not load centers
Yes something like that is a good option and is actually what I did at my house. It appears the OP may have need for a separate generator back up panel though.So why not just go with a single 400 amp panel with 84 spaces then?
You say that assuming I'm going to pay $40+ for AFCI breakers. LMAO I'll have GCFI's within 6ft of water but I'm not buying into the AFCI BS.Shorter runs usually work better with GFCI and AFCIs as well
This throws off the stud spacing unless you have 24" spaced walls (which are legal and cheaper!). Or, you have to fit a 14.5" panel in a 13" space. Interior wall can be fudged, as sheetrock is usually laid lengthwise along the wall, but exterior wall means something going on with those 8 x 4 OSB panels laid vertically (or you have different sheathing methods).I always have the framer put double studs between the panels.
Some of us kind of agree with where you are likely coming from there but still have to pass inspections.You say that assuming I'm going to pay $40+ for AFCI breakers. LMAO I'll have GCFI's within 6ft of water but I'm not buying into the AFCI BS.
