Ballast for G36T8 36W fluoriscent bulb
alex6999
New member
Toronto, ON
Hi.
I need to use germicidal lights in my appartment
I found PLT G36T8 48" at 1000bulbs
I also found Phillips G30T8 36", but I cannot find 3 feet fixture at reasonable price.
My choice T12 2 bulbs fixture with new ballast
1000bulbs answer about G36T8 only: The bulbs you selected run on a specialized ballast we do not carry on our website
Yes, they have only 32W ballast on their website.
36W 110V ballast not exists.... I think. I didnt found.
I can take 220V from stove, but prefer not to do it.
I found
http://www.lightingsupply.com/b232punvel-b.aspx
Universal Programmed Rapid Start FL Ballast for 1-2 F32T8 F40T8 F17T8 Lamps, Parallel Wiring Run at 120 - 277 Volt (B232PUNVEL-B)
This ballast able to run one 40W lamp or one or two 32W lamp.
May be stupid question, but will it run with one 36W bulb?
I going to run 1 bulb in bedroom and 3 bulbs(to cover by UV every corner and kitchen) in living room
I found
http://www.lightingsupply.com/b432punvhe-a.aspx
Universal Programmed Rapid Start High Electronic Fluorescent Ballast for (3-4) F32T8 F40T8 F17T8 Lamps - 120V-277V (B432PUNVHE-A)
It able to run 3 40W or 3-4 32W
I going to run 3 bulbs in different fixture from 1 ballast
Specs allow Remote Mounting: 20 ft. max. lead length, 18 AWG
Since 2 bulbs fixture cheaper than 1 bulb fixture, I thinking to install 2 bulbs, one germicidal and one regular F32T8
Its absolutly no reason to run this bulbs together.... so any way to run them from one ballast?
Probably not. I will install 2 programmed ballast to run 3 lights(each ballast)
and 1 instant start ballast to run 36W germicidal bulb. I will turn it on twice a week, so Rapid Start not a big issue.
I found this
https://www.ebay.com/itm/391344500038
Kelmar Electronic Ballast Model 240 for 1 or 2 F40T12 or F40T8 Un-Shunted Lamps 0.80A
Not sure againg if it will work with 36W bulb. Will it work?
and 1 ballast for F32T8.... so here is wide-wide selection
One more question.
T12 fixture usually have shunted or not-shunted sockets?
And will T8 bulbs fit?
For example this
https://www.ebay.com/itm/132385462449
Thanks
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.[/noparse]
