Bats in the belfry
Danger Will Robinson!! Danger!!
LarryFine said:
Some people are easily amused. Glad I could help. :grin:
LOL Thanks Larry.. :)
But the new pic of that disconnect has me a lot less amused....what an accident waiting to happen. This new pic shows the corrosion on the bottom of Fuse 1 as well.
Chris Kennedy said:
Thats real nice to know. Again, IMO the right tool for this job is a bulldozer.
The two most common causes of Bulldog explosions (in my own experience anyway) is lack of interrupting capability (usually due to mechanical failure between the handle linkage and the contacts, they drag open and arc, causing internal flashover) and in one case I saw, the ENTIRE INTERIOR slammed forward into the front door when the handle was operated (the interior mounting screws were completely corroded away.)
After the first incident I learned one of the most valuable safety lessons: NEVER stand directly in front of any disconnect or breaker, always stand to one side and look away when operating them. I've never had anything more serious happen than a singed glove that way.
LarryFine said:
Even that is still a scary thought. I might have added wet pants to that.
Thank you mxslick. I took a closer look today and the bolts that hold the guts in don't look to bad. Of course where they thread into the can...???
Since there is only about 20 feet of wire between the trannys and the line lugs I'm guessing pretty high AFC.
