Why don't you focus on actually answering the OP's question rather than blabbering on about a bunch of irrelevant stuff and getting a bunch of that stuff wrong?
Sounds like you're angry because I went into a through explanation about the subject matter.
As an educator it is my position to explain answers and not to simply glide over the answer with a " bunch of irrelevant stuff and getting a bunch of that stuff wrong".
Some questions require more than "just because" or "that's the way we do it". So, what kind of 'irrelevant stuff' was written that may have offended you or disagreed with you?
You certainly have the right to share a different version of it but back it up with NEC Code sections.
Most likely it'll mean that you will have to do a little research and maybe some" blabbering" to get your point across.
The easy way out is to just don't read any post that you think is totally irrelevant and has no sensible answer because of too much information.
TX+MASTER #4544
Thanks for reading.
Comments accepted.
