Re: Big oops ... need suggestions
Originally posted by GeorgeStolz:
Perhaps we should re-define this sucker.
What do you think it might look like?
Here's a little background quoted from the Codes I have here:
1933. Outlet. A point on the wiring system at which current is taken to supply fixtures, lamps, heaters, motors, and current-consuming equipment generally.
1935. Outlet. A point on the wiring system at which current is taken to supply fixtures, lamps, heaters, motors, and current-consuming equipment generally.
1940. Outlet. A point on the wiring system at which current is taken to supply fixtures, lamps, heaters, motors, and current-consuming equipment generally.
1947. Outlet. A point on the wiring system at which current is taken to supply fixtures, lamps, heaters, motors, and current-consuming equipment generally.
1951. Outlet. A point on the wiring system at which current is taken to supply fixtures, lamps, heaters, motors, and current-consuming equipment generally.
1953. Outlet. A point on the wiring system at which current is taken to supply fixtures, lamps, heaters, motors, and current-consuming equipment generally.
1956. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1959. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1962. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1965. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1968. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1971. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1975. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1978. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1981. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1984. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1987. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1990. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1993. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1996. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
1999. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
2002. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
2005. Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
