- Lockport, IL
- Retired Electrical Engineer
Re: Big oops ... need suggestions
. . . post #500!
. . . post #500!
Originally posted by al hildenbrand:
The definition of Outlet says nothing about the return of the current, unmodified or energy used.Originally posted by Larry Fine:
To me, fed out to a switch, and then back in 'unmodified' isn't the same as fed out to a load, energy used, and returned to the neutral.
</font>Originally posted by Larry Fine:
Questions: </font><font size="2" face="Verdana, Helvetica, sans-serif">
- <font size="2" face="Verdana, Helvetica, sans-serif">1. Is any place the wiring is accessible (a blanked-off junction box, e.g.) an outlet, or only where a device or "whip" is fed?</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">2. What if a switch is removed (bypassed) because, say, a fixture with a remote has been installed?</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">3. What about a box where a receptacle has been removed and the wires joined to continue the circuit?</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">4. How about a dedicated-circuit-fed receptacle or the last receptacle on a circuit that has been removed?</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">1. No to the first half, and either end of the whip can be the outlet, depending upon who assembled the whip.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">2. Then there is no longer an outlet occuring where the switch had been.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">3. If there is no longer a receptacle there, it is no longer an outlet, only a j-box.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">4. Same as #3.</font>
Great questions.Originally posted by LarryFine:
So you agree, then, that it is the presence of the device (or fixture, disconnect, whip, etc.)that defines the outlet? To avoid wasted e-space, that's what I mean when I say that you're saying a switch is an outlet. The switch makes the box the outlet, right?
No.
And, No.
I'm having trouble following the logic. You seem to be contradicting yourself. No wonder I'm confused! :roll:Originally posted by al hildenbrand:
Part of the definition of the boundary for the Rule for the middle section has to allow parts in the middle of the middle section to not be under the rules of the middle section.
Well, that is after the fact. I'm not laying out new Code, nor a proposal for the same.Originally posted by Sandsnow:
When will you be sending in your proposal?? Time is running out!!
It took me a while to get to this, too.Originally posted by Larry Fine:
If you want THE answer from the only people who matter, then send in a proposal. It will be answered by being accepted or rejected with accompanying explanation.Originally posted by al hildenbrand:
210.12 requires that the question be answered, in my opinion.
The manufacturer's internal workings of their electrical product are regulated by NRTLs and the published listing regulations, no?Originally posted by charlie b:
Yes. They have to be listed. How they get that way is up to the manufacturer, and the NEC does not tell them how to build the switch. But the switch itself is not beyond the jurisdiction of the NEC.
A proposal to what effect? As I read the NEC, the Code already exists.Originally posted by sandsnow:
Continuity, yes.Originally posted by roger:
as well as a snap switch can.
Yep, it is as safe as all other wiring within the bedroom walls that is not serving the bedroom.Originally posted by al hildenbrand:
Dwelling occupant safety?
Originally posted by jwelectric:
I see that it made it to over 500.![]()
