EUREKA!! EUREKA!!! EUREKA!!!! I finally am getting it...........
You say that the three pipes are delivering the same amount of water. But to what are they delivering it? If they are connected to sprinklers, they deliver the water to the garden. They could instead be taking water from one tank and moving it to another. They could be taking water from a river, running it through some heat exchangers in an industrial plant, and delivering slightly warmer water back to a point further down the river. In none of these cases is the water that leaves its source required to make its way back to the same source. But current that leaves an electrical source (generator, transformer, UPS, battery, etc.) must necessarily make its way back to the same source that put it into motion in the first place. In a 3-phase system, you have 3 paths that current can take as it leaves the source. But whichever path it takes on its way out, it will take one or both of the other two paths on its way back.
I now get it lucidly because of Mr. Beck's explanation, Smart $'s avatar, and all of the other inputs. That avatar is powerful. Why wasn't I focusing on this stuff so many years ago when I was in school, a teenager, and I knew it all????
What I was missing is that an energy transfer from electric current to magnetic field with circulation of fluid to sustain it was not being modeled. Let me elaborate.
First exit the "real" world and welcome to the "ideal" world where losses and eddy currents and friction are absent.
Consider a large frictionless hollow doughnut pipe that is filled with non-compressible fluid laying on an oval racetrack. At each oval end consider there is a perfect turbine that is 100% efficient. A little magic here works well. A mechanical shaft to drive or driven by the turbine blades is accessible outside of the pipe. Of course the seals are frictionless and never leak. Since there are no losses and we are talking 100% efficiency any rotation of drive turbine shaft (generator) will replicate the identical motion on the driven turbine shaft (Motor). Let us call the generator end G (generator). Let us call the other end M (motor).
Now I can completely understand every item I could not before. Three single phase services are three independent oval MG systems. A three phase service is the composite sum of the three 120 deg staggered sinusoidal waves applied as torque to the G end. This will have some ripple. 50 phase will have minimal ripple. Infinite phases are a continuous circular drive motor driving the G end and the M end will be a fixed RPM driven shaft just like an induction motor.
The inductive coupling is in the circulatory fed back fluid. There are reactance effects due to pipe length and diameter.
If I modify the diameter of the hollow doughnut pipe I am modelling a transformer. If I vary sine wave period of input torques I vary speed.
This is fun. Try it out. See if you can debunk it.
Please try to find a reason that I am missing something. I am here to learn.
