hurk27
- Portage, Indiana NEC: 2008
Run a 250.66 sized GEC to the water pipe at street side of water meter jumper to the house side of water filter, and be done with two clamps.
Run a 250.66 sized GEC to the water pipe at street side of water meter jumper to the house side of water filter, and be done with two clamps.![]()
250.53(D)(1) Continuity. Continuity of the grounding path or the bonding connection to interior piping shall not rely on water meters or filtering devices and similar equipment.
because I can run one conductor instead of two, to serve both 250.52(A)(1) requirement, and 250.104(A)'s requirement.
and ask your self this question. Why is the following located in the grounding electrode article and not in the bonding article?
claiming a solid metal body mixing valve similar to a "plastic water filter" is a bit of a stretch, or a readily removable water meter for that matter. nothing similar to either
You are the closest so far to understanding me.
The hot water tank is NOT bonding the two (as I call it) seperate systems.
There is NO tee between the hot and cold (systems).
I am debating 250.104(A)(1) and nothing else.
250.104(A)(1) only takes us to 250.64(A),(B), and (E); and 250.66 NO other code section.
"Likely" nor is "energized" is in 250.104(A)(1)
250.104(B) does not apply to """""metal water piping"""".
For George
Short answer.
I believe that the hot and cold are seperate system(s).
"Clearly, the CMP has no concern for bonding the hot water pipes unless they are deemed to be likely to be energized." No it is NOT clear.
Where is "likely to be energized" discussed for metal water piping? That is for other metal (does not say water) piping. Metal water piping is discussed first. Then we go to other metal piping.
The ?S? means such things as gray water such as in a irrigation system, circulating hot water used for heat or cooling, and the potable water system. All of these are water systems. If either of these are not 100% metal water pipes then they are ?other? piping systems. In other words they are something different than complete metal water piping systems.For a second forget that other metal piping is in the code. Just look at metal water piping system(s) Again why is there a (s) in that section. Please give me some examples of what you think the system(s) are that the code refers to.
What I am saying is that if I see any nonmetallic piping what so ever I am not going to install a bond of any kind.So are you saying if these system(s) are isolated in 'any' way they need not be bonded?
Wayne
"also there are water meters that we are not required to bond across, that are solid body (imagine that), the water meters that have the X frame that doesn't break the continuity of the water pipe when the meter is removed, is not required to have to be bonded across, and I have seen a write up on that one by some national board, just cant remember where I saw it, it showed several water meter yokes that didn't not require to be bonded across."
I agree with you. Again we are starting to agree.
Thank you. What is similar equipment?
Anyone:
Show me where, in writing not an opinion, plumbing fixtures are part of the metal water piping system(s). They are not.
Is a switch part of a branch circuit?
A fixture sounds like it could be 'equipment'.
Mike,Is a switch part of a branch circuit?
Mike,Anyone:
That is how an electrically isolated section of conductive water piping becomes Other Metal Piping covered by 250.104(B).the National Electrical Code Making Panel quotes clarify that the 250.104(A) phrase metal water piping system must be COMPLETE, otherwise the water piping falls under 250.104(B).
