Blaine Hall
- Coarsegold, CA
My business installs removable fencing in the decks surrounding swimming pools.
The NEC 2002 Edition, Article 680 (swimming pools, fountains, and similar installations),
Sub section: Article 680.26 Bonding (A) Performance: The bonding required by this section shall be installed to eliminate voltage gradients in the pool area as prescribed.
Sub section 680.26, 680.26 paragraph (3) (Metal Fittings) states: All metal fittings within or attached to the pool structure shall be bonded. Isolated parts that are not over 100mm (4 in.) in any dimension and do not penetrate into the pool structure more than 25mm (1 in.) shall not require bonding.
Question:
Background: We drill a 1 1/4 diameter hole completly through the concrete deck. We then insert a non-conductive 4" tall cylindrical sleeve with a bottom and a lip to seat against the top surface of the deck into the deck. It is this sleeve that the aluminum fence poles go into. The aluminum poles are 30" on centers connected by a non conductive polyester/nylon mesh. The product is safety fencing to keep young children and toddlers safe from the hazards of the swimming pool.
Does my product require bonding to eliminate the voltage gradients and identified in section (A) above, or is there not a voltage gradient hazard since the poles are inserted into a non-conductive sleeve?
Blaine Hall
Question:
Blaine Hall
