- Windsor, CO NEC: 2023
- Hospital Master Electrician
If the customer is a little fruity, a little overkill pays dividends.
If the customer is a little fruity, a little overkill pays dividends.![]()
The difference is, in single family one-off construction, there is a lot less money floating around for change orders, and people irrationally take it personally when they come along, and are loathe to sign a check based on their own mistake. It makes a $20 gimme worth more than a few hours on the phone explaining to three different people what happened.
I wire for today, if they want it changed in the future I can come back and and for a price make that change.
Giving away work makes no sense.
Isn't running circuits without knowing the requirements stupid?
If it helps me get the job done I might install more than what is needed to cover my rear.
On the other hand in this case the OP has the info from the manufacturer any deviations from that are on the customer.
For a single run it is really no big deal, if it is a 30 unit apartment building it is a big deal.![]()
Yes if you don't know about the equipment and you don't want to wait for your own reasons pulling more makes sense.
But again, in this case the EC has the specifications for the unit, if the customer changes their mind afterwards I make money for that change.
I have no idea why this has become so difficult. :?
I have installed 125 volt 20 amp outlets for pizza ovens based on the specifications given me, when the units arrived they needed two 50 amp 3 phase 208 circuits.
Should I have pulled two 6/3 MCs ahead of time even though the info should only one 12/2 needed?
I made a killing on that change, changes are where the money is in construction.
I would be interested to know if the OP installed 10-3 to the water heater.
Come on, be real. How many water heaters have you ever seen that required a neutral? I have never seen one, except gas models that just needed a 120V receptacle for ignitors, etc.
Ovens & cooktops are constantly reinvented. It is only common sense to think a little ahead on them.
I think the reason you are even having this discussion in the first place, is there is a trend for more and more appliances to have a neutral.
I've been told that it's for the control circuits and the light. The heating elements don't need it. If that's the case, I think we ought to be allowed to pull a #14 in the pipe but I'm told we can't do that.
Thanks Mike
