gadfly56
- New Jersey
- Professional Engineer, Fire & Life Safety
In the US, it was:
"A pint's a pound the world around."
Except it isn't.
The error at 70F is 6.5% OMG!!!:jawdrop:
In the US, it was:
Except it isn't.
Check post #33.You said finer. I and They said better.
Don't know where you get that from but the 20 oz v 16 oz pint is rather more than 6.5%.The error at 70F is 6.5% OMG!!!:jawdrop:
But my simple point was that a pint isn't a pound the world round.
Check post #33.
You clearly did not, and do not, understand understand the meaning of finer in the context it was used.Okay, get the flowchart out.
In #31 I said BETTER.
In #32 You said FINER
In #33 In poor phrasing I attempted to correct you that FINER was not desired, it was a BETTER fit.
Blah Blah and Blah
And Goldilocks tried the little bed and it was just right.
At least I have an excuse - I'm not English.Thank You all It's been a interesting topic. I notice why we are electricans,
& not english teachers because a lot of us can not spell.
You might also have added that one cubic metre of water weighs one tonne.
And, for the benefit of pfalcon, I do mean a tonne, not a ton.
Yes, it was. I was just noting another convenient conversion.That would have been redundant since the weight/volume relationship was already referenced.
HI ALL,In air-conditioning system calculations,use is solely made of the Fahrenheit system.So it may not be possible to get rid of Fahrenheit system entirely from Engineering.For the most part, the metric system is better. But, as for temperature, the fahrenheit system is preferable because it uses a smaller unit than the centigrade system. One degree centigrade is almost two degrees fahrenheit.
Since we now use American units, I think it wise that the Code should get rid of the metric system and use the American system.
~Peter
There are 10 kinds of people in the world - those who understand binary and those who don't.Not really, it would be 4096g (dec). It would just be written as 1000g (hex).
Good points with historical perspective. A pound being 16 ounces divides down nicely for weighing out parts of pounds to a resolution of one part in 16 with a mechanical balance. Nice in that you need relatively few counterweights to get all single ounces in discrete steps.I may be stating the obvious, but the reason for the oz/lb and oz/gal relationships is that in order to weigh or measure something accurately all you need is a double pan balance for weights or identical containers for liquids. If you start with an accurate lb or gal, you can get to an oz or oz without having to have a standard weight or volume handy. That is not true of the metric system; you can't start with a kilo and get to a gram with a pan balance.
Why did we go with celisus for tempature factors ? Everybody knows 98.6,
32, 212. We can all relate to these farenheit tempatures. We never adopted
the meter, liter, kilometer at least not in wide use.
Forgive me if this has been posted already. I started reading through this and got bored to tears. But the way I convert C to F is take the degrees in C and multiply by 1.8 then add 32 and you get F.
