Chase nipple ul listed for Bonding
Many, including me, will vehemently disagree with you here. In a recent thread in fact I was complaining that AC cable should be more common over MC. I do think minimum fitting quality needs to be a bit higher and/or enforced.
IMO there is no real significant difference between MCAP and AC cable. I'm sure there there is some rather technical differences that still makes a difference per listing standards though.
Then there is steel clad vs aluminum clad versions.
Did a Google search and it stated NPSM ( or American Standard Straight Mechanical Pipe Thread ) and they do not have a taper pipe thread. Type NPS stands for National Pipe Thread and have a tapered thread. When I started as an apprentice our electric shop had an old set of 1/2 to 2" Rigid stock & dies that only the sparkies were supposed to use. A know it all plumber asked to borrow them and I tried to explain that I was told they were not for use on plumbing pipe. Of course he told me that I was another dumb rookie. He threaded at least halve a dozen pieces of schedule 40 pipe for a 125# steam line. He spent hours taking first leaking joint and applying more pipe dope, put it together then tried fixing next leak. End of day somebody in our shop that heard our conversation told him he used the wrong dies. These dies did not produce a tapered thread and hopefully no longer produced. Came across European 2 to 5 KW immersion heaters that had straight threads. Some how it was the electricians job to remove bad heaters & wrench in new ones. Luckily we had a very talented chief electrician and he finally told us how to stop threads from leaking water. After we applied several layers of Teflon pipe tape wrapped two pieces of sewing threads onto taped threads. These heaters were on melting kettles and little pump only produced 10# of water pressure.
My mini excavator is foreign made machine. The hydraulic lines have what looks like normal pipe thread but if you try to use a NPT fitting on them they will leak as they are non tapered. The socket end fittings have a inverted flare that must seat to the flare in the male end of the fitting and that is what makes the actual seal. When you blow a hose and have one made up you can't use NPT ends, it must have the ones designed for this setup.
We were told at an IAEI continuing education class maybe 8 years ago that AC cable has a thicker wall jacket but I could not see any difference between AC & MC cable jacket. Would specify aluminum jacket MC cable when I was pulling long runs if 10/3 & 10/4 thru drop ceilings. Bad thing about the aluminum jacket found it to have more oil residue on jacket. Like to have a dollar every time I had to clean off dirt on drop ceilings from excess oil. Old school never once wore gloves to pull wire or cable.
