EMFExplorer
- Nashville
- EMF
Why do you suppose utilities settle these lawsuits outside of court for millions of dollars per lawsuit? If it's such a crazy conspiracy theory, why don't they want them going to trial? I've been on the dairy farms where ground current is making animals sick - very sick - and causing severe health problems to farmers and their families as well. Some of it is onsite and some of it is offsite ground current. It's not a joking matter. Laugh if you want, but it kills people and causes cancer and many other health issues. Numerous well-programmed studies have shown that as little as 18 microamps of current applied to the body causes cancer. It also depends on what frequencies are there, but the bottom line is current belongs in electrical cables not outside of them.I'll be selling tin foil hats for $5 each plus shipping. That should take care of the problem...
-Hal
Balancing the current in the cables also reduces electromagnetic fields, which are a 2B agent on the WHO's IARC cancer agents lists - the same as lead, DDT, and engine exhaust. A lot of amazing researchers and published scientists, medical doctors, engineers, and other professionals have been pushing for better (lower) public exposure standards for these things. Wake up.
@mtnelect I hadn't seen your thread(s) yet. I will read them. Your knowledge is probably greater than mine. I don't claim to understand as much about voltage regulation and lightning. I know there are solutions that could improve the parallel current paths issue as well as be totally acceptable for other needs, too. It will cost money, but it represents an important improvement in how we can be safe and healthy with electrical distribution. From my work under and learning from Dave Stetzer, I know that neutrals must be oversized to accommodate our non-linear loads. Bigger neutrals, or running a second neutral in a 5-wire system, and better neutral connections everywhere lower the impedance of the neutral thereby greatly lowering the current taking the earth.
Of course these pipe paths are amazing low-impedance paths, so they need to be electrically insulated with pex/etc.
But we should head in the right direction and limit the damage and death caused by electrical current taking paths other than their intended conductors. We do this inside buildings - code requires it - so we should do it outside as well.
