gar
- Ann Arbor, Michigan
- EE
221205-1105 EST
Therealcrt:
I will try to teach you something about logical circuit design using GE RR relays.
The RR relay is a bistable SPST switch controlled by two coils. One coil performs the SET function, closing the SPST. The other coil performs the RESET function, opening the SPST bistable contact. So the RR relay is the same as an ordinary SPST toggle switch, except it is electrically operated, whereas the ordinary toggle switch requires finger actuation. The RR has two separate stable states that only require momentary actuation to change state. The RR is electrically controlled, whereas the toggle switch requires your finger at the switch location to change state.
With the RR relay I can have many SPST-NO momentary switches in parallel in different locations control the ON state of the relay. The same for the OFF function. And the particular lights controlled by a particular switch can be different for ON and OFF.
With appropriate logical circuits I can have one low voltage switch control many relays. This means I can have individual switches control a single circuit or have have a single switch control many circuits. Both types of control can simultaneously exist. Time clock signals can be at the low voltage level, and ON and OFF control can be different. For example ON of all lights could occur at some time, and OFF might require manual control.
Therealcrt:
