jljrandall
New member
- Victor, Montana
Need some help. (this application is on a dairy) (this is a privately engineered design). I have a generator that used to be a 3 phase motor, that has been rewound to be a generator? It is driven by a 454 methane fueled engine. (they are using the cow manure), The name plate says 240/480V, 50 KW,60 Hz. The Utility company installed a 3 phase 120/208 bank for this dairy. The 3 Phase wye is brought all the way to the transfer switch, (I could attach a hand sketch if you like), They bonded at the first means of disconnect, ( a sqare D I line panel 600A) and the Nuetral of the wye in on an insulated lug and dead ends in the transfer switch. (most gen systems I have seen installed have been single phase and the Nuetral of the gen is tied with the Nuetral of the Permenant power in the the auto transfer switch. Well my question is is that the I am being told that the dairy uses the utility power to apply the field and maintain the field because the supplier of this home made contraption has not supplied the exciter package yet. (So when the gen is on line it is always connected to the Utility grid, their is no sync control, no meter watching voltage, freq, or amps) Well, that seems a little dangerous to me in my gut, with the influx in frequency in by utility and out by the gen?, and then I get to looking at this thing and they have only 3 phase wires and 1 equipment ground going to the head of the motor? The dairy seems to think that if they had there exciter package they could operate as a stand alone unit, ie, run a few lights, operate their HMI controls for milking, some pumps ect., my question also is where are they going to get there Nuetral? They are under the assumption that if the Utility has a power outage they will just use the Utility system nuetral from the the 120/208 bank out at the pole. The big 3 phase gens I have hooked up before had 3 phases, a nuetral and a gound. A lot of things do not seem right, electrically here and I can not quite put my finger on it or have the code knowledge with these home made generation systems people are wanting to install weather it be wind, solar, water, or methane fueled to lower their KW usage from the power company and in some cases customers are wanting to do a net metering agreement with the local Utility. I have dug in 705 and 445 and I am stuck, and I need your help.
thanks alot.
Jason
thanks alot.
Jason
