mstrlucky74
- NJ
Well the conduit went from 3" to 4" and the conductors are larger so I'm assuming that they would be more labor intensive. IMO 4" is overkill for those 4 conductors.
What type conduit, and is it being run in/on structure or laying in a trench?
Aluminum will be lighter, which will be a little easier on a worker that is directly handling it, but you are dealing with sizes that very likely still will use same pulling and handling equipment for a run with much of any length to it at all.
On structure... yea labor is a bit less for the AL wire but still cost more overall to install the AL scheme.
I don't see how it results in a 70% increase in labor. Increasing from 3" to 4" doesn't make sense either for 3 500 kcmil conductors.
4 sets of each according to your scheduleAdditional set, increase in conduit size and increased conductor size..although Aluminum.
For your viewing pleasure....
Mind you these are right from our supply houses and very close to buy prices350 Cu $4.70/ft ? Southwire >$11
500 Al $1/ft ? Southwire $5 latest contractor bulk
Al http://www.southwire.com/documents/AL_BLDG_Wire_42AC.pdf
