mstrlucky74
- NJ
Very sorry..couldnt capture the entire pic....totals were far below on screen...just add up each row total for material and laborSo what are the totals for each?
Sent from my SM-G955U using Tapatalk
Mind you these are right from our supply houses and very close to buy prices
Lol...i will see post when I get home.I'm too lazy to bother and since you have them you're too lazy to post them.![]()
4/0 Cu is $8.50/ft
you have it at $4.10
500 Al
you $1.30
Southwire distributor 1.2.2018 price list $4.90
where did your labor hrs come from?
delta ~35 hrs
Just calculated totals on fly...thinks it's close
Alum- material $4700 labor 158 hours
Copper - material $11500 labor 123 hours
I don't see how it results in a 70% increase in labor. Increasing from 3" to 4" doesn't make sense either for 3 500 kcmil conductors.
I'm at a loss to explain why if Al can potentially show a commercial advantage.
I've followed this thread and found it quite interesting.
Slightly different take.
The comparison of Cu and Al - it just doesn't happen here in UK.
Everything is geared to Cu conductors. Lugs, markers, sleeving, cable glands, terminals.....
We made electrical panels, mostly VSDs with conductors up to 240mm^2 (about 500MCM). All copper conductors.
I've looked in a couple of our main supplier's catalogues and neither lists Al cable.
Remember, we are talking about conduit and single conductor, not multi conductor armored cable.[/QUOTE]
Which is, however, also used frequently in the US and apparently not used in the UK.
The wiring internal to our panels was single core run in slotted trunking to keep it neat and tidy. No real space constraints.Remember, we are talking about conduit and single conductor, not multi conductor armored cable.
Besoeker, view it as saving copperWe size cable based on a mostly fixed table and loads of other conservative rules. In short we love using lots of metal. Using AL helps conserve a limited resource for the smaller circuits.
