e57
- San Francisco, CA
I know a few others, but difficult to make acronyms out of them...The only 'factor' I know is the PITA!!!![]()
I'm wondering how/why someone would price a 100a service at half of what they would a 200a service. The labor is almost identical, and the parts costs aren't that far apart.
I never price a job by the anything. I'd rather drive there and know about the inevitable snag before I give a price.
So, if in fact, prices are going to be going down the tubes for some time to come....then the average $/amp will to, for ballpark toss out figures.
It's just sad to know that folks leave more $$ on the table now a days. $1000 service upgrade???? Not good to hear.......
Those figures are only used to caclulate a toss out figure to the shoppers wanting a price over the phone. You know the ones...they tell you they think they need an upgrade and want $$ price over the phone, dont want you to come out and give an accurate one, even after you inform them that it is best to take a look and see if one is really needed, etc.... and if so, it will allow you to give them the best bang for the buck.....
The area economic conditions will change the burdened labor, but usually, not the material or profit figures, so the gross difference will vary from 10 to 20% across the country, and there are some depressed areas, where rates can be much lower, but in those areas the cost of living in that area makes it a wash, when a contractor figures his costs of doing business, the area econimic conditions, and cost of living, is part of setting a rate.
[FONT=Arial (W1)] [/FONT]
Re: Service change and misc Electrical
We are pleased to provide pricing for the referenced project as per walk thru on 10/06/2009 and the following.
Inclusions:
? Due to Fluctuating prices of cooper and steel, the estimated price will be adjusted
- Replace existing30 circuit FPE split bus service with 200amp Service 40 circuit panel
- Install new circuit breakers for existing circuits
- Install new 200amp rated meter housing
- Install customer provide Motion light at location of Breaker panel
- Install new circuit and circuit breaker for motion light
- Install 1 ground rod for main service
- Install main System ground wire to with in 5 foot of where main water enters house/aprox 50 foot
- Install 1 outlet let on wall behind bar for TVtapped off exsting outlet directlly below
- Replace existing outlet(1) on Kitchen counter with GFCI outlet
- Install new ceiling electrical box aprox 18” from existing box for New Dinning room light
- Electrical Permit from City of Littleton
- coordination with Excel Energy for permanent connection of over head lines
- Onsite and present to meet Electrical Inspector
- Excludes:
- any arc fault breakers
- Any addition items as required by city electrical inspector not related to service
- Change
- Interface communication Grounding/ Bonding for communications
- Purchase of Out side Motion Light and Electrical box for Light
? according to prices at time of delivery
? Total price for work as outlined above for Service upgrade Only $1260.00
? Price to install bar outlet $75.00
? Price to replace Kitchen Outlet and add new ceiling box In Dinning room$100.00
? Total Price for all above work $1435.00 Balance due upon completion
If you have any questions or require additional information, please call.
$1260?
............. If this is they way things are heading, we're all in big trouble. Might as well work at McDonalds, at least they'll give you bennies.
Well, maybe. They're not all the same, nor all the same everywhere.$1260? For a service change? Holy crap.
Let's see:Your materials are at least 500, RIGHT?
I'm assuming you'll be there for 8 hours, right?
Sitting for the inspector will take at least 2 hours out of your day.
Permit will be at least 60.
Permanent connection from the power company costs $250 where I'm from.
For the 100a service, $1260 (which I agree is still a bit low) would mean about $900 before cost deductions. I'd probably get around $1500 to $1800.500 + 60 + 250 = 810. That leaves you a whopping $450 for the day. Paid over 10 hours with the 8 hour day and 2 hours of inspection. $ 45 an hour without paying any overhead or taxes yet.
So, that's why the Mickey-D employees are smiling all the time.Might as well work at McDonalds, at least they'll give you bennies.
Let's see:
No new meter base, indoor 100a MB panel and, say, two 2p and ten 1p breakers, and grounding: $200-ish.
New meter base, indoor 200a MB panel and, say, five 2p and 20 1p breakers, and grounding: $300-ish.
Permit and inspection, including application time, say $150-ish. POCO supplies meter bases free.
No POCO charges for an upgrade, and I've never paid them a penny for anything anyway; that's the customer's baby.
I'm rarely onsite for a residential inspection. So far, that's about $350 to $450 for basic material and permit costs.
For the 100a example, maybe six hours, for the 200a example, maybe eight. Let's say a full day either way.
Of course, there's open wall vs. flush-mounted, whether back-to-back is plausible, whether service cable has to be replaced, etc.
For a 200a as described, I'd probably get about $2200 to $2500, depending again on ancillary work required. If I need a 3R disco and had to snake an SER, we're up to $3000.
There's no set price for anything, except TS time. I can't imagine pricing any service without visiting the jobsite, and maybe a conversation with the POCO for non-residential.
The base. I've never, ever bought a meter base, single, multi, or CT. They always provide the meters.Your POCO gives you a meter base for free, or just the meter?
if you can't make good money on a service upgrade then it isn't worth it. I would have quoted around $2400.00 for the service and other work and I would have had 2 guys there for 1 day.
I would have paid about $400 in labor for the 2 guys, $600 in material and permit, which leaves $1400 for the company expenses and profit. If I was one of the guys on the job my labor cost would be only $200 as I own the company. so that would have been $1600 for the company expenses and profit. (of course I pay myself out of the $1600)
You can't sweat not getting this job - let some other stew ball lose money and work for free.
Added: I've also never had to install a through-the-roof mast, although I've done plenty of wall risers.
That is just plain weird.
The POCO gives you meter bases?
I want you POCO here!!
