lordofthisworld
- Massachusetts
Which means your ground prong is always set either up or to the left, then... or have I forgotten the rule???
It’s a preference, not code.
This is the main reason why people install ground up on receptacles
Maybe we should all install with ground pin up?
Maybe we should consider the wisdom of mounting receptacles at 18"? Always hated them ending up behind beds, nightstands, dressers, etc. Don't know code but would it be "illegal" to put them 48" AFF? Not like they are many things that need to sit on the floor.
With no ground pin in what was plugged in it wouldn't have made any difference at all, still shorting the same two points together.This is the main reason why people install ground up on receptacles
Excellent point, Most everything today is double insulated, lamp cords phone chargers, printers etc.
NEMA shows ground up; I've always thought it's because plugs are more resistant to downward pull-out.This is the main reason why people install ground up on receptacles
If a receptacle would happen to be marked "top" then it must have that end up. Most anything beyond that is taboo topic here as there is no correct answer.NEMA shows ground up; I've always thought it's because plugs are more resistant to downward pull-out.
Not taboo, just 100-page capable.Most anything beyond that is taboo topic here as there is no correct answer.
I still think TR is a gimmick that was mandated for..., well you know.
A determined enough child will defeat TR. If sticking something in one slot does not work why not both which will result in a more dangerous shock. Key is parenting and watching after kids.
I have installed TR receptacles in homes with small children, only to come back and see they put those plug in caps we have seen for years in all the receptacles the child may ordinarily have access to. Some owners may not have been told they are TR and that might be understandable, but others have been told and don't remember or understand anyway, but I still say that they did it because they do think about safety of their child. Not going to say that people don't care about child safety, but many don't care enough to give it much thought until they see something happen.
Yes some of them now have black shutters and is harder to tell at a glance it is a TR receptacle.until now, I had not given much thought to the fact that if a kid defeats a TR receptacle, he (and I do say he since it's more than likely going to be a boy doing this) is probably going to require two hands and get hit hand-to-hand with an electric shock, Which is far as I know is the worst way to get hit as electricity tends to pass straight through or across the heart.
The saving grace is that you would have to be fairly determined to defeat the TR, and a great many kids nowadays are not going to have the attention span to go grab another paperclip and try again.
Locks are made to deter lazy thieves. TR receptacles
will deter curious but lazy kids.
Kwired, I was trimming out a house a few years ago and went into a mild panic when I thought the 15 or so receptacles I had installed were not TR. They were, however they had black shutters for the TR, so looking at them at a glance they looked very much like a regular duplex receptacle.
If you ask me those plugs are better. Tony will say however otherwise.![]()
I’d better say otherwise. My names on a report to be submitted to a House of Commons select committee regarding BS1363.
And for the British 1363 I'd say so, but not for the US NEMA 5-15r.
The BS1363 plug is ridiculous. Other than the sleeved pins, the Euro plug is much better.
You mean the schucko?
